I am creating pin planning for Arria 10ax057,
i used 2A Bank for GPIO with 1.8V my compilation was successful.
in other requirement i have to use LVDS pins, so i removed few GPIO's and taken few 13 sets of LVDS signals, and rest are 1.8V.
Now my fitter is giving error.
Error(11702): I/O standard assignment ' 1.8 V' to pin FPGA_IO43 is not supported by the device. The name ' 1.8 V' is not a valid I/O standard name
before using LVDS pins from the bank, i faced no issues
Queries:
1) In single bank can i use both LVDS and 1.8V ? If not suggest the document where i can find this information
2)Is it only 2A bank, (as PCIe hard ip reset is used from 2A) or it is same for all banks.
Rajesh
How are you creating the assignment? Pin Planner? Assignment Editor? It looks like there's a space in front of 1.8 V that probably shouldn't be there.
You can also try running I/O Assignment Analysis from the Processing menu or Pin Planner. That might provide more detail on the issue.
You can refer to this document to see the requirement for LVDS: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/arria-10/a10_handbook.pd...
I would suggest to begin with page 101.
Thank you for reply.
as 2A bank is having configuration, and i used those as BIDIR . so it caused error.
when configuration pins ignored/taken as input to design the issue is solved.
Rajesh
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
