FPGA Intellectual Property
6158 Discussions
IPS-EMBEDDED Datasheet
Dear All,
I want to buy the embedded ip suite[1]. Here is hong kong so I check any international distributor can sell this product.
After some searching from altera site, I found mouser [2] with this product link [3].
The Code is matched (IPS-EMBEDDED). The price is matched ($995USD).
However there is a datasheet attachment [4] labeled as ("IPS-EMBEDDED Datasheet") and it doesn't match with the product
The title of the datasheet attachment is "Low Latency 40- and 100-Gbps Ethernet MAC and PHY MegaCore Function User Guide".
However, the description of IPS-EMBEDDED from altera site is :
Embedded IP Suite: A value bundle that contains licenses for the Nios II processor IP core, Triple-Speed Ethernet IP core, 16550 compatible UART and high-performance , DDR/DDR2/DDR3 SDRAM IP cores and high-performance DDR SDRAM IP core
Please kindly help I want to double confirm [3] is really the product I am looking for. The datasheet attachment is really confused me.
Ken
[1] https://www.altera.com/products/processors/embedded-ip-suite.html
[2] https://www.mouser.hk/
[3] https://www.mouser.hk/productdetail/intel-altera/ips-embedded?qs=%2fha2pyfadui9bgz%2fk8crqdi0ftqpif1jvwctnk2j4lowm49um1cimw%3d%3d
[4] https://www.mouser.hk/datasheet/2/612/ug_ll_40_100gbe-1098819.pdf
