I'm using IVP suit's scaler to up conversion an static image, using paralell input of RGB signals. I simulated the instantiated scaler in Modelsim. the stimuli is provided as the example waveform in "video and image processing suuit, v8.0 user guide". when the simulation started. I get the following error in modelsim:
# ** Warning: (vsim-3534) [FOFIR] - Failed to open file "alt_vip_scl_gnlb6pxv23_h_coeffs_reg_file_contents.hex" for reading.# No such file or directory. (errno = ENOENT) : F:/test_scaler/sim/altera_mf.v(785)# Time: 0 ps Iteration: 0 Instance: /top/dut1/n0O011i# ERROR: cannot read alt_vip_scl_gnlb6pxv23_h_coeffs_reg_file_contents.hex.# ** Warning: (vsim-7) Failed to open readmem file "alt_vip_scl_gnlb6pxv23_h_coeffs_reg_file_contents.ver" in read mode.# No such file or directory. (errno = ENOENT) : F:/test_scaler/sim/altera_mf.v(40973)# Time: 0 ps Iteration: 0 Instance: /top/dut1/n0O011i the dout_read and dout_valid signals are always in "x" state. Why this happens? can anybody explain this?Link Copied
you have to copy your .hex files in your project path not in your ip path !
