FPGA Intellectual Property
6356 Discussions
In Triple Speed Ethernet core, what does the COPPER_LINK_STATUS refer to?
RMcco
I'm debugging an Ethernet link that fails after several hours of temperature testing. We're using the TSE core in an Arria 10, configured in the 10/100/1000Mb Ethernet MAC with 1000BASE-X/SGMII PCS configuration, with LVDS I/O.
When the unit is in the failed state, the values in PCS register 0x05 have COPPER_LINK_STATUS=0, COPPER_DUPLEX_STATUS=0, and COPPER_SPEED=00
It's not clear from the documentation - are these registers for the SGMII link between the FPGA and the PHY, or are they trying to pull the status from the PHY of the link between the PHY and the remote device?
Put another way, do these indicate a SGMII problem, or a PHY problem?
RMcco
Reading through documentation, it looks like the copper status flags are supposed to be coming from the PHY, via the control information SGMII bus. (It would be nice to have that confirmed).
However, I can confirm that the PHY currently believes that the link is up, in 1000Base-T, in full duplex. So there seems to be some issue with the SGMII bus overall.
SengKok_L_Intel
Hi Ryan, the register 5 of PCS is used for update the partner ability during auto-negotiation. Do you mean, when before the issue happen, the value is 1, but after failure happen, it became 0? Do you perform auto negotiaion? How about other LED status signal before and after failure? Regards -SK Lim
RMcco
Hi SK -
You are correct - those bits are set appropriately while the link is operating normally, and after it fails, they are set to zero. I am in the process of capturing other before/after data. We are using auto-negotiation.
Can you confirm if the copper status flags are in fact being read by the TSE from data supplied over the SGMII bus? Also, if the TSE does see bad status, will it automatically re-auto-negotiate?
Thanks -
-Ryan
SengKok_L_Intel
​Hi
You can refer to the PCS control register bit 9 and bit 12. Software can trigger the re-start auto-negotiation. If you read those value with zero, i believe the auto-negotiation may be failed. Please capture more status signal to confirm.  And how about if your manually trigger the auto-negotiation again? Will it back to normal?
Regards -SK Lim
RMcco
Hi SK -
I believe I tried restarting auto-negotiation to no effect, but will need to confirm. If it helps, below are register dumps in the good and bad states for the PCS block (note that the addresses are byte addresses and not word addresses). I captured two different failures (rebooted in between and ran until failure again) - they seem to have differences that may be significant.
Also, the PHY we're using is a TI DP83867, if that makes any difference.
Thanks -
-Ryan
Good state:
0x00040a00   0x0000:1140
0x00040a04   0x0000:00a9
0x00040a08   0x0000:0000
0x00040a0c   0x0000:0000
0x00040a10   0x0000:41a0
0x00040a14   0x0000:d801
0x00040a18   0x0000:0003
0x00040a1c   0x0000:0000
0x00040a20   0x0000:0000
0x00040a24   0x0000:0000
0x00040a28   0x0000:0000
0x00040a2c   0x0000:0000
0x00040a30   0x0000:0000
0x00040a34   0x0000:0000
0x00040a38   0x0000:0000
0x00040a3c   0x0000:0000
0x00040a40   0x0000:0000
0x00040a44   0x0000:1101
0x00040a48   0x0000:0d40
0x00040a4c   0x0000:0003
0x00040a50   0x0000:0003
0x00040a54   0x0000:0000
0x00040a58   0x0000:0000
0x00040a5c   0x0000:0000
0x00040a60   0x0000:0000
0x00040a64   0x0000:0000
0x00040a68   0x0000:0000
0x00040a6c   0x0000:0000
0x00040a70   0x0000:0000
0x00040a74   0x0000:0000
0x00040a78   0x0000:0000
0x00040a7c   0x0000:0000
Bad state 1 ( Reg 0x5 = 0x0040)
0x00040a14   0x0000:0040
Bad state 2 (Reg 0x05 = 0xC2A0):
0x00040a14   0x0000:c2a0
RMcco
Hi SK -
One additional question: Registers 0x12 and 0x13 set the link timer value. According to the datasheet, the default value is 0x98968 - if those represent 8 ns ticks, that works out to 5 ms. But the datasheet says that the default is 10 ms. Is there an additional factor of two somewhere?
Also, the PHY we're using (TI DP83867) has four options for the SGMII link timer: 11 ms, 800 us, 2 us, and 16 ms. We're using the default, which is 2 us (which seems very short). This doesn't seem to be breaking auto-negotiation itself, but it's unclear if this also has an effect on the TSE declaring if/when the link goes down.
Thanks -
-Ryan
SengKok_L_Intel
​Hi Ryan,
I don't think the link timer is a concern, if yes, then it should fail at first start the auto-negotiation. If there is a doubt, you may try to adjust it and see if any improvement.
Regards -SK Lim
