This is an issue sharing, related to Agilex 7 FPGA R-tile MCDMA PCIe IP design example:
After programming the Multi-Channel DMA Intel® FPGA IP for PCI Express Design Example targeting the Intel® Agilex 7 FPGA R-Tile devices A0 or B0 die revision, the PIO tests will fail, and the DMA tests report queue reset failures.
DK-DEV-AGI027RES : AGIB027R29A1E2VR0 = A0 die revision.
DK-DEV-AGI027R1BES : AGIB027R29A1E2VR3 = B0 die revision.
Solution:
A patch is available to fix this problem in the Intel® Quartus® Prime Pro Edition Software version 22.4
Regenerate and recompile the test design after installing the patch.
- Intel® Quartus® Prime Pro Edition Software v22.4 Patch 0.02 for Linux (.run)
- Intel® Quartus® Prime Pro Edition Software v22.4 Patch 0.02 for Windows (.exe)
- Readme for Intel® Quartus® Prime Pro Edition Software v22.4 Patch 0.02 (.txt)
