My enviorment :
Executable: quartus
Comment:
None
System Information
Platform: linux64
OS name: SUSE LINUX
OS version: 12
Quartus Prime Information
Address bits: 64
Version: 21.2.0
Build: 72
Edition: Pro Edition
I got the following error :
Internal Error: Sub-system: RTM, File: /quartus/tsm/rtm/rtm_recommendations.h, Line: 4980
Did not find any relevant domains on ENDPOINT_MY_DOMAIN for recommendation of type 6 in Clock Domain bt_utmi_clk_A.
Offending node(s):
n_data_A[0]
Stack Trace:
Quartus 0x7565f: (ccl_msg)
Quartus 0x2ac7c8: RTM_DOMAIN_CLASSIFICATION_SCHEME<(RTM_RECOMMENDATION::ENDPOINT_INDEX)0>::filter_recommendation(RTM_RECOMMENDATION*, RTM_FLOW_STATE&, std::vector<RTM_RECOMMENDATION*, std::allocator<RTM_RECOMMENDATION*> >&) + 0x3b8 (tsm_rtm)
Quartus 0x2aee2a: RTM_BASIC_CLASSIFICATION_SCHEME::BASIC_CLASSIFIER<RTM_DOMAIN_CLASSIFICATION_SCHEME<(RTM_RECOMMENDATION::ENDPOINT_INDEX)0> >::classify_recommendation(RTM_RECOMMENDATION*, RTM_FLOW_STATE&) + 0x5a (tsm_rtm)
Quartus 0x2aa379: RTM_BASIC_CLASSIFICATION_SCHEME::BASIC_CLASSIFIER<RTM_TYPE_CLASSIFICATION_SCHEME>::classify_recommendation(RTM_RECOMMENDATION*, RTM_FLOW_STATE&) + 0x1c9 (tsm_rtm)
Quartus 0x2aa99d: RTM_BASIC_CLASSIFICATION_SCHEME::BASIC_CLASSIFIER<RTM_SUPERCT_CLASSIFICATION_SCHEME>::classify_recommendation(RTM_RECOMMENDATION*, RTM_FLOW_STATE&) + 0x1ad (tsm_rtm)
Quartus 0x2948ab: RTM_ROOT_CLASSIFICATION_SCHEME::CLASSIFIER::classify_recommendation(RTM_RECOMMENDATION*, RTM_FLOW_STATE&) + 0x17b (tsm_rtm)
Quartus 0x303a6d: RTM_RECOMMENDATION_GENERATOR::generate_latency_recommendation_for_rdg_node(RTM_RECOMMENDATION_CLASSIFIER*, RDG_NODE const&, VLAT_TYPE, VLAT_DIRECTION) + 0x15d (tsm_rtm)
Quartus 0x303fe8: RTM_RECOMMENDATION_GENERATOR::generate_recommendations_for_rdg_nodes(RTM_RECOMMENDATION_CLASSIFIER*) + 0x2d8 (tsm_rtm)
Quartus 0x304fb5: RTM_RECOMMENDATION_GENERATOR::generate_recommendations(RTM_RECOMMENDATION_CLASSIFIER*) + 0x55 (tsm_rtm)
Quartus 0x289e31: RTM_REPORT::get_info_for_step(std::vector<std::vector<unsigned long, std::allocator<unsigned long> >, std::allocator<std::vector<unsigned long, std::allocator<unsigned long> > > >&, Tcl_Interp*, RTM_SLACK_VEC const&, bool, bool, bool, bool, RTM_REPORT::FFC_STAGE_INFO&) + 0x1c1 (tsm_rtm)
Quartus 0x28aa04: RTM_REPORT::add_fast_forward_step(std::vector<std::vector<unsigned long, std::allocator<unsigned long> >, std::allocator<std::vector<unsigned long, std::allocator<unsigned long> > > >&, Tcl_Interp*, RTM_SLACK_VEC const&, bool) + 0x2c4 (tsm_rtm)
Quartus 0x2fd76f: RTM_FFC::run_outer_loop() + 0x12af (tsm_rtm)
Quartus 0x8d3c1: RTM_FLOW::run_rtm_flow_outer_loop_fast_forward() + 0x91 (tsm_rtm)
Quartus 0xa22e4: RTM_FLOW::retime_circuit(void*) + 0x34 (tsm_rtm)
Quartus 0xa247e: RTM_FLOW::retime() + 0x15e (tsm_rtm)
Quartus 0xb04cc: FDRGN_EXPERT::do_retime() + 0x12c (fitter_fdrgn)
Quartus 0xb4f8e: FDRGN_EXPERT::retime() + 0x74e (fitter_fdrgn)
Quartus 0xb668d: FDRGN_EXPERT::fastforward() + 0x5d (fitter_fdrgn)
Quartus 0x28726: fit2_fit_fastforward_auto + 0xd3 (comp_fit2)
Quartus 0x4c942: TclNRRunCallbacks + 0x42 (tcl8.6)
Quartus 0x1670b: fit2_fit_fastforward + 0x291 (comp_fit2)
Quartus 0x4de7b: TclEvalEx + 0x68b (tcl8.6)
Quartus 0xf3f0e: Tcl_FSEvalFileEx + 0x25e (tcl8.6)
Quartus 0xf3ffe: Tcl_EvalFile + 0x2e (tcl8.6)
Quartus 0x14405: qexe_evaluate_tcl_script(std::string const&) + 0x452 (comp_qexe)
Quartus 0x188f2: qexe_do_tcl(QEXE_FRAMEWORK*, std::string const&, std::string const&, std::list<std::string, std::allocator<std::string> > const&, bool, bool) + 0x3d9 (comp_qexe)
Quartus 0x198ab: qexe_run_tcl_option(QEXE_FRAMEWORK*, char const*, std::list<std::string, std::allocator<std::string> >*, bool) + 0x559 (comp_qexe)
Quartus 0x3472d: QCU::DETAIL::intialise_qhd_and_run_qexe(QCU_FRAMEWORK&, FIO_PATH const&, std::string const&, std::string const&, char const*, std::list<std::string, std::allocator<std::string> >*, bool) + 0xc5 (comp_qcu)
Quartus 0x38e04: qcu_run_tcl_option(QCU_FRAMEWORK*, char const*, std::list<std::string, std::allocator<std::string> >*, bool) + 0x225 (comp_qcu)
Quartus 0x1d1ce: qexe_standard_main(QEXE_FRAMEWORK*, QEXE_OPTION_DEFINITION const**, int, char const**) + 0x61f (comp_qexe)
Quartus 0x403272: qfit2_main(int, char const**) + 0x92 (quartus_fit)
Quartus 0x40136: msg_main_thread(void*) + 0x10 (ccl_msg)
Quartus 0x40d6e: msg_thread_wrapper(void* (*)(void*), void*) + 0x64 (ccl_msg)
Quartus 0x1528e: mem_thread_wrapper(void* (*)(void*), void*) + 0x5e (ccl_mem)
Quartus 0xcdc0: err_thread_wrapper(void* (*)(void*), void*) + 0x1e (ccl_err)
Quartus 0x6ba5: thr_thread_wrapper + 0x15 (ccl_thr)
Quartus 0x4186f: msg_exe_main(int, char const**, int (*)(int, char const**)) + 0x148 (ccl_msg)
System 0x20765: __libc_start_main + 0xf5 (c)
Quartus 0x402b49: _start + 0x29 (quartus_fit)
End-trace
Any suggestion how can I solve it ?
I haven't found similar fatal error in the database. Could you help to share your design .qar file that could duplicate this error?
We will need to duplicate the error as without the error duplication from our side, it would be hard to find a workaround/solution.
Richard Tan
Hi
Sure , please send pointer to secure and Intel access only .
Yishay
I have send you an email on how to transfer the file. Please kindly check your inbox.
Richard Tan
I do not see this IE in the Quartus Pro 22.4.
Could you try to run the project in the latest Quartus Pro version?
Richard Tan
Hi
Did you run my design.qar at 22.4 version without any IP upgrading ?
Yes, in fact there is no IP upgrade needed when I open in 22.4.
Richard Tan
Please be informed that there will be delay in response in the following week due to holiday season.
Richard Tan
Hi
Thank you
Indeed the problem is solved
I checked it with version 22.3 ( currently , I dont have 22.4) and I dont see this issue any more
Yishay
Wishing you a Happy New Year 2023!
Sometime upgrading to the latest version help to resolve the IE issue (not always though) as bugs has been fixed with each Quartus release.
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Thank you.
Richard Tan
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
