Hello!
I want to interpolate a 13.5 kHz sinus signal, which is generated with a NCO at a sampling rate of 54 Khz. I want a sampling of 5,4 MHz. So i tried to use a CIC-Filter with rate = 100. What I get at the output of the CIC-Filter is a 4.5 kHz sinus signal !! --> there is something wrong! What is the problem here ?? I tried different types of stages and delays, but I won't get a 13.5 sinus. please help me.. Thanks!Link Copied
it could be useful a post of your schematic.
How many samples has a single period of the high frequency sine signal at the output?- Mark as New
i think there is a problem with your CIC hardware, because input samples should be synchronized with c0 clock and output samples should be synchronized with c1 clock. Note this, for every input sample 100 samples must go out.
In your hardware, an input sample (synchronized with c0) is read 100 times by a module clocked with c1. As you are using two clocks, in your CIC hardware a dual-clock FIFO for crossing clock domains must be included.- Mark as New
Ok. I was thinking in your way too. Because the differentiators has to be clocked with the lower sample rate and the integrators has to be clocked with the higher rate. But I thought the CIC-Filter would do this "clocking" automatically.
The CIC-Filter generated by the MegaWizard has only one clock-input.....how should I solve the problem??...- Mark as New
so, you are driving in the wrong way the avalon-streaming signals. in_valid line must be asserted every 100 cycles of 54 MHz clock.
parrado, while i agree with you conceptually this is not how the Altera generated test bench operates.
tobias, have you taken a look at the CIC generated test bench? also take a look at the output error signal in your project.- Mark as New
Aha!
@Parrado: This could be the solution! I will try tomorrow in the lab.....in germany know it's 10:20 pm. Thank You parrado! I will let you know if it works.... @thepancake: I will have look at the generated testbench file and the error output too. I will let you know tomorrow. Thanks..- Mark as New
Hello!
I tried to connect the "valid in" with the lower clock. When I set the rate to 5 it works fine. But with a higher rate like 10 or 100 I get a 4.5 kHz-Sinus....it's weird. But I think it is the right way to "clock" the valid in, because in the "functional description" of the CIC-Filter you can see that the "valid in" is clocked too.- Mark as New
I am not fans of CIC IP cores but judging by your last work there is possibilty of error. You are supposed to drive the input data in once every 100 clks of output clk. By connecting slow clk to valid in you will violate that when clk is high since many fast clks will be enabled.
OK. So I should set "valid in" set to "VCC" ? How about "clken", "reset_n" and "out_ready" ..... they should be connected to "VCC" too ?
Again I don't know about your set-up and IP signals. But the role is 1:100.
It is your responsibility to clk data in at 1/100 of output rate. Then it is the responsibility of CIC IP to give you the correct output. One way is this enable at a rate of 1/100, connect to valid_in: -- detect the edge of slow clk in the fast clk domain: wait until fast_clk = '1'; clk_1d <= clk_in; clk_2d <= clk_1d; enable <= clk_1d and not clk_2d; edit: make sure clks are synchronised- Mark as New
Hello kaz !!
Now the CIC-Filter is working! With detecting the edge of the slow clock and insert this to the Valid_In. Thank you very much! Tobias- Mark as New
Hi tobias ,are you here ? I found your question about cic filter and is helpful to me, can you upload your worked design of cic filter quartus project here ? Thanks !
The CIC-Filter generated by the MegaWizard has only one clock-input.....how should I solve the problem??... ___________________ Save your time and get on time success in a plus computer certification (http://www.pass4sure.co.uk/lx0-102.html) and testking toefl exams by using our latest comptia a+ (http://www.pass4sure.co.uk/lx0-101.html) and other superb n10-005 (http://www.pass4sure.co.uk/comptia-a-plus-training.html) pass resources of quincy university (https://www.faceboo.com/quincyuniversity) and southwestern college (http://www.youtube.com/user/southwesternccd)- Mark as New
The CIC core has a streaming interface involving input and output valid signals rather than separate "clocks". The output rate will be in fact generated automatically with respect to the input rate. Review the documentation!
