As I understand it, you are inquiring about the RapidIO example design for C10GX devices. For your information, currently there is no example design generated from the IP. I have also searched into our database but could not locate any specific design on this. Sorry for the inconvenience.
As a workaround, you might need to start by creating simple test design and run through simulation to verify functionality. Then slowly add more modules into the design. Sorry for the inconvenience.
