I'm using quartus 10.1 sp_1 version. I just instantiated pos_phy level 4 megacore function. After I generate the IP core, It gives following files. 1. *_tx_core.v2. *_tx_modules.v 3. *_altfifo_concat.v 4 *.v 5 *_tx_data_proc.ocp 6 *.sdc and all submodules. The issue is in *_tx_core.v file. In this files there are reset_syncer and *_altfifo_atltop instants.when i start compilation i got error as *_reset_syncer & *_altfifo_atltop module not found. when i create the IP core, it should generate all required *.v files, but in my case these two files are missing. thanks in advance VinodLink Copied
