FPGA Intellectual Property
6670 Discussions
Issue with Remote Update State Machine
Jcole
While looking for sample designs invoking the RSU via a state machine, I came across an older intel/altera design. The code is designed to repeatedly ping-pong between the factory image and the application image; however, I've gotten varied results. The FPGA will boot the factory image, then use the RSU to boot the application image successfully. When the application image tries return to the factory image, the FPGA does not successfully load and becomes completely unresponsive until reprogrammed.  For my design we are using a S25FL256 to hold the SOF files.
The Code for each state machine is below and attached to this post:
Factory_image.v
module c10rsu //factory image
#( parameter APP_IMAGE_START = 32'h00800000,   //copy this address directly from EPCQ datasheet
  parameter TIME_BETWEEN_STATES = 32'h01777777 )
//  BLOCK		START ADDRESS		END ADDRESS
//  Page_0		 0x00000000		   0x007FFFFF    (0x006C16A3)    Sector 0   to  127
//  Page_1		 0x00800000		   0x0100FFFF    (0x00EC16A3)    Sector 128 to  255
( input wire  c10_clk50m,
  output [3:0] led );
//  wire        clk40;
  reg  [31:0] data_in;
  reg  [ 2:0] param;
  reg         read_param;
  reg         reconfig;
  reg         reset           =  1'b0;
  wire        reset_timer		=  1'b0;
  reg         write_param     =  1'b0;
  wire        busy;
  wire [31:0] data_out;
  reg  [31:0] count           = 32'b0;
  reg  [ 2:0] state           = 3'b000;
  wire        pof_error;
  //The count LED serves as a heartbeat, to see the design is functioning
  assign led[3] = (count[21] );
  //LEDs to show the state
  assign led[2:0] = ~state[2:0];
  //State Machine:
  //0:  Reset the remote system update circuitry
  //1:  Release the reset
  //2:  Empty State
  //3:  Set LEDs to indicate why we are in state
  //4:  Set the address for the application image
  //5:  Disable the watchdog timer
  //6:  Boot the application image
  //7:  Hold
  always @(posedge c10_clk50m)
  begin
    case (state)
	 //Reset the remote system update circuitry
	 3'b000: begin
	     count <= count + 1;
		  reset <= 1'b1;
		  param <= 3'b000;
		  read_param <= 1'b0;
		  data_in <= data_in;
		  write_param <= 1'b0;
		  reconfig <= 1'b0;
		  if (count==TIME_BETWEEN_STATES) begin
			 state <= 3'b001;
		    count <= 32'b0;
		  end
	   end
    //Release the reset
	 3'b001: begin
	     count <= count + 1;
		  reset <= 1'b0;
		  param <= 3'b000;
		  read_param <= 1'b0;
		  data_in <= data_in;
		  reconfig <= 1'b0;
			 state <= 3'b010;
			 count <= 32'b0;
	     end
	   end
	 //Empty state
	 3'b010: begin
	     count <= count + 1;
			 state <= 3'b011;
			 count <= 32'b0;
	     end
	   end
 	 //Set LEDs to indicate why we are in state and set AnF to 1
	 3'b011: begin
	     count <= count + 1;
		  reset <= 1'b0;
		  param <= 3'b101;
		  read_param <= 1'b0;
        reconfig <= 1'b0;
		  data_in <= 32'h00000001;
		  if (count[29]==1'b0)
		    write_param <= 1'b1;
		  else
			 state <= 3'b100;
			 count <= 32'b0;
	     end
	   end
	 //Set the address for the application image
	 3'b100: begin
	     count <= count + 1;
		  reset <= 1'b0;
		  param <= 3'b100;
		  read_param <= 1'b0;
		  reconfig <= 1'b0;
        data_in <= APP_IMAGE_START;
		  else
   	   		state <= 3'b101;
	   		 count <= 32'b0;
	     end
	   end
	 //Disable the watchdog timer
	 3'b101: begin
	     count <= count + 1;
		  reset <= 1'b0;
		  param <= 3'b011;
		  read_param <= 1'b0;
		  reconfig <= 1'b0;
        data_in <= 32'h00000000;
		  else
			 state <= 3'b110;
			 count <= 32'b0;
	     end
	   end
	 //Boot the application image
	 3'b110: begin
	     count <= count + 1;
		  reset <= 1'b0;
		  param <= param;  //output
		  read_param <= 1'b0;
		  data_in <= data_in;
		  reconfig <= 1'b1;
			 state <= 3'b111;
			 count <= 32'b0;
	     end
	   end
	 3'b111: begin
	     //Still counting so it can be demonstrated that factory image is still working
		  count <= count + 1;
		  reset <= 1'b0;
		  param <= param;
		  read_param <= 1'b0;
		  data_in <= data_in;
		  reconfig <= 1'b0;
		  //No way out of this state without an external event, this is the error condition
		end
	 default: begin
	     count <= count + 1;
		  reset <= 1'b0;
		  param <= param;
		  read_param <= 1'b0;
		  data_in <= data_in;
		  reconfig <= 1'b0;
			 state <= 3'b000;
			 count <= 32'b0;
	     end
	   end
    endcase
  end
  //Cyclone V remote update
  remote_update	remote_update_inst (
	.clock(c10_clk50m),//clk40),
	.data_in(data_in),
	.param(param),
	.read_param(read_param),
	.reconfig(reconfig),
	.reset(reset),
	.reset_timer(reset_timer),
	.write_param(write_param),
	.busy(busy)
endmodule
Application Image
odule c10rsu //application_image
#(parameter TIME_TO_FACTORY = 32'h08777777)
( input wire  c10_clk50m, //input  clk,
  output [2:0] led );
//  wire        clk40;
  reg         reconfig = 1'b0;
  reg  [31:0] count_to_factory = 32'b0;
 assign led[2] = count_to_factory[21];
 assign led[1] = count_to_factory[21];
 assign led[0] = count_to_factory[21];
//counter for lights and back to factory.
 always @(posedge c10_clk50m) //clk40)
  begin
		count_to_factory <= count_to_factory + 1;
		if (count_to_factory == TIME_TO_FACTORY)
			reconfig <= 1'b1;
	end
//Instantiate the remote update block
  	  .clock(c10_clk50m), //clk40),
	  .data_in(32'b0),
	  .param(3'b0),
	  .read_param(0),
	  .reset(1'b0),
	  .reset_timer(1'b0),
	  .write_param(1'b0),
	  .busy(),
     .data_out()
endmodule
Jcole
I believe I was able to solve the problem, the addressing I was using for my Serial interface was incorrect and setting my pointer to a much lower location than intended. When the sector erase was executed I believe it was over writing a portion of the data that was used to hold the Factory image.
Jcole
To add new information gained during debugging, the issue of not returning to the factory image, seems to occur when my GSFI module is enabled in the FPGA code. If this module is not enabled, the system will return to the factory image. I do not have the GSFI state machine running when the RSU state machine is running (for obvious reason), but is there an underlying issue between the two modules? Does the flash used to house the image data need to be in a protected state for the RSU to work?
ShengN_Intel
May I know where you get the design? Possible share the link here?
Sheng
Jcole
