FPGA Intellectual Property
JESD204B Loopback
Is there a model for the JESD204B IP running in loopback mode? Something similar to what is available for the arriaV native PHY IP (http://www.alterawiki.com/wiki/arria_v_transceiver_phy_basic_design_examples)?
Are you able to find any option of enabling loopback in the IP? I know that for some IP ie TSE, the loopback option is there. If not, you might need to contact Altera to see if there is any workaround ie editing some files.
