FPGA Intellectual Property
LVDS SERDES IP
ymiler
Hi
I have task to transmit data from 1 board to another
Each board has FPGA stratix 10M
To do it - I use LVDS SERDES IP in  FPGA (TX) and other LVDS SERDES IP in FPGA (RX)
All the pins define as LVDS (including clocks & data)
My problem is : Sometimes pll lock flag doesn't lock
I don't know what is root casue for that - but I sample the clocks by scope
You can find it in the attached pic :
Do I need change the IO standard ?
Do I need change the internal termination ?
BR,
Yishay
ymiler
Hi
Do you know what could be the reason for the unstabilty lock ?
Each reset / PWR on/off  or FPGA loading  get another lock flag value from the SERDES IP port
Yishay
Ash_R_Intel
You may want to look into the terminations applied to each of the LVDS pins. Also, you can check on the RREF pins. For more details, please refer the Stratix 10 Pin connection guidelines. https://www.intel.com/content/www/us/en/programmable/documentation/lod1484643014646.html#wsh1484644837897
Regards.
Ash_R_Intel
We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
