I am trying to implement a LVDS to RGB converter in the DE1 board. I am using the LVDS and PLL IP Megafunction. I used as a template the "Design Example 2: Cyclone II ALTLVDS Using External PLL Option" from the ALTLVDS Megafunction User Guide. I changed the FPGA used because it's not the exact same one as in the DE1 board. Then when I am assigning the pins to the expansion header of the DE1 board (I also precise in the "I/O Standard": LVDS), Quartus Fitter gives me the following error: "Error: Can't place PLL "lvds_pll:inst2|altpll:altpll_component|pll" -- I/O pin "ref_clock" (port type INCLK of the PLL) is assigned to a location which is not connected to port type INCLK of any PLL on the device" Can somebody explain to me what this error means and how I can solve it? Thank you in advance, MeachLink Copied
Hi Meach,
You probably use an ordinary I/O pin for your ref_clock. You ref_clock must be connected to a dedicated clock input. Success, Ton- Mark as New
Hello Ton,
Yes I am using one I/O pin from the expansion header because I thought that I need to get somehow the LVDS clock. If I want the LVDS data to be synchronised, how can it be if I don't have its clock in input? Meach- Mark as New
Aditionally, you can't use LVDS with the DE1.
The GPIO pins are connected to a bank powered at 3.3V VCCIO. For LVDS, they'd have to be connected to a back with 2.5V VCCIO and have the proper external resistors. Among the examples and documentation of the DE1 board, you should have a mock up project that contains just an empty top level and all the correct pin assignments. I suggest you take it as base for any project you do on the DE1.- Mark as New
Oh great!
There is no possibilities to use it anyway with the DE1? For the pin assignment I prefer doing it myself for any project. I prefer to check them anyway every time and so far I do not need to assign every time all the pin of the board. Meach- Mark as New
So like rbugalho wrote: no LVDS for DE1. Too bad.
But if you ever gonna design your own board, make sure your LVDS-clocks are connected to a pinpair labeled "LVDSCLK" in http://www.altera.com/literature/dp/cyclone2/ep2c20_ep2c15a_ep2c20a.pdf. And make sure the external termination is right (I used 100 Ohm with success). Good luck, Ton- Mark as New
For now I am only interested in development board but if I will design my own one later, I will keep that in mind.
Also this is a bit off topic but basically if I want to use the LVDS protocol with a development board, I have to make sure that the board has adjustable Input Signal Levels, right? rbugalho said that it should be connected to 2.5 VCCIO. But I read that the maximum input voltage of LVDS is 2.4 V. So for example with 1.8 VCCIO, will it work? Thank you Meach- Mark as New
To use LVDS with a development board, the board needs to have a LVDS interface.
IIRC, the Cyclone III starter kit has. VCCIO is the voltage that powers the I/O elements. The maximum LVDS signal voltage is 2.4V but the FPGA I/O elements must be powered with 2.5V for LVDS. Trying to use LVDS with 1.8V VCCIO is not document anywhere, AFAIK, and it will problably not work.- Mark as New
ok thank you rbugalho, that's exactly what I wanted to hear!
I made some research and instead of looking for another development kit I think I will go for a Quad Link LVDS Interface HSMC Daughtercard + GPIO-HSMC Card and the DE1. Meach
