I'm currently debugging issues with the QSE 10G IP core embedded into an FPGA (Arria10) connected via PCIe to the system CPU (PC). Sometimes the RX mSGDMA reports this error: RCV pktstatus 00000020 pktlength 00000558 ... My current best guess about the pktstatus read from the mSGDMA controller (status from the response FIFO), is that it represents rx_status/error from the MAC (MAC manual page 90): avalon_st_rxstatus_error[] Out 7 When set to 1, the respective bit indicates thefollowing error type in the RX frame. • Bit 0: Undersized frame. • Bit 1: Oversized frame. • Bit 2: Payload length error. • Bit 3: CRC error. • Bit 4: Unused. • Bit 5: Unused. • Bit 6: PHY error. The IP core presents the error status on this bus in the same clock cycle it asserts the avalon_st_rxstatus_valid signal. The error status is invalid when an overflow occurs. Is this assumption correct? And if yes, 0x20 means bit 5 and this is "Unused" in the table above. So what could this error mean? Thanks, StefanLink Copied
