FPGA Intellectual Property
The Intel sign-in experience is changing in February to support enhanced security controls. If you sign in, click here for more information.
6065 Discussions
MCDMA/PCIE max number of channels - how to get 256 physical channels
grspbr
Hi @wchiah ,
I am recreating this question because the older one was closed. There is a problem with notifications. I am not getting notifications of replies to my posts. How can I correct this?
To get to the problem, The MCDMA/PCIE core has 11 bits of DMA channel address when using multiple logical channels on one physical interface. We planned to use 256 channels (physically) but probably only a dozen or so logical channels. However, when we try to drive it using Intel's DPDK, we seem to get corruption of the D2H DMA descriptors if we use more than 64 channels. Why are we seeing this limitation? Is it in the DPDK itself? Also, it seems we cannot use logical channels that we can map to a physical channel address. It seems that the creation of channels automatically uses sequential physical channel addresses starting from 0. Is it not possible to map logical channels to physical channels?
To answer your question, we are using Quartus 21.2 for Agilex AGFB014 (P+E Tile).
In our build settings, we have:
PCIe0 Settings/PCIe0 IP Settings/PCIe0 PCI Express/PCI Capabilities/PCIe0 Device/PF0 = 256; and PCIe0 Settings/PCIe0 IP Settings/MCDMA Settings/D2H Prefetch channels = 256; and Maximum Descriptor Fetch = 16
grspbr
Hi @wchiah
I have sent you a link (by email) where you can retrieve the QAR files from our cloud server.
Greg
wchiah
I wish to follow up with you about this case.
Do you have any further questions on this matter ?
​​​​​​​Else I would like to have your permission to close this forum ticket
Wincent_Intel
grspbr
Hi Wincnet, I still need to review your last response.  I should have something tomorrow.
Greg
wchiah
I wish to follow up with you about this IPS case.
Hoping to hear back from you so that we can proceed for next step.
Wincent_Intel
wchiah
Hi Greg,
Thanks for the .qar file and evidence.
I had rise an internal engineering ticket for this.
The related team will work on it, will follow up closely, let you know if there is any update.
Wei Chuan
wchiah
Hi Greg,
We might need perfq_log_20230106_143546.txt and 22.4 ED qar file.
can you put it in google drive and share me the link ?
Wei Chuan
wchiah
Hi Greg,
I can access to your link.
Can you please attach perfq_log_20230106_143546.txt for Quartus v22.4 as well ?
with 256 channel fail log.
Wincent_Intel.
grspbr
Hi Wincent,
Unfortunately, I don't have the compiled project anymore for v22.4. But it behaved exactly the same as v21.2. It was an intel example project that I just changed the settings for 256 channel.
Greg
wchiah
Hi Greg,
I have tested 22.4 acs branch and 22.4 acs Qshell using design example from Quartus with given command, and not observing any issue.
Please find bitstream and release software in attachment. Also confirm are you using DCA enabled ZTE sof? if so this Quartus build won't support DCA feature.
Test output:
[root@BAPVECISE040T perfq]# ./build/mcdma-test -- -b 0000:01:00.0 -p 8192 -l 2 -z -c 64 -a 1 -d 4
EAL: Detected 16 lcore(s)
EAL: Detected 1 NUMA nodes
EAL: Multi-process socket /var/run/dpdk/rte/mp_socket
EAL: Selected IOVA mode 'PA'
EAL: Probing VFIO support...
EAL: PCI device 0000:01:00.0 on NUMA socket -1
EAL:  Invalid NUMA socket, default to 0
EAL:  probe driver: 1172:0 net_mcdma
PMD: ifc_mcdma_get_hw_version(): MCDMA RTL VERSION : 0x50001
PMD: ifc_mcdma_get_device_caps(): Max Supported by DPDK: 1024
EAL: PCI device 0000:04:00.0 on NUMA socket -1
EAL:  probe driver: 8086:15f3 net_igc
EAL: PCI device 0000:05:00.0 on NUMA socket -1
Allocating 64 Channels...
BDF: 0000:01:00.0
Channels Allocated: 64
QDepth 508
Number of pages: 8
Completion mode: WB
H2D Payload Size per descriptor: 8192 Bytes
D2H Payload Size per descriptor: 8192 Bytes
H2D SOF on descriptor: 1
H2D EOF on descriptor: 1
H2D File Size: 8192 Bytes
D2H SOF on descriptor: 1
D2H EOF on descriptor: 1
D2H File Size: 8192 Bytes
PKG Gen Files: 1
Tx Batch Size: 127 Descriptors
Rx Batch Size: 127 Descriptors
TID FIFO Checks: OFF
AVST Example Design Interface
DCA: OFF
Thread initialization in progress ...
Thread is in READY state...
Thread initialization done
All Threads exited
TIME OUT while waiting for completions
Leaving...
-------------------------------------OUTPUT SUMMARY------------------------------------------
Dir #queues  Time_elpsd   B_trnsfrd      TBW   d_drop_cnt Passed Failed %passed
Tx   64   00:03:457   26185368.00KB  17.11GBPS    0    64   0   100.00%
Rx   64   00:03:457   24388064.00KB  09.46GBPS    0    64   0   100.00%
Total Bandwidth: 26.57GBPS, 3.48MPPS
Total TX Bandwidth: 17.11GBPS, 2.24MPPS
Total RX Bandwidth: 9.46GBPS, 1.24MPPS
Total data drop count :0
Full Forms:
TBW:      Total Bandwidth
IBW:      Interval Bandwidth
MIBW:      Mean Interval Bandwidth
HIBW:      Highest Interval Bandwidth
LIBW:      Lowest Interval Bandwidth
Please refer to perfq_log_20230125_120711.txt for more details
     total_drops:0
[root@BAPVECISE040T perfq]# ./build/mcdma-test -- -b 0000:01:00.0 -p 8192 -l 2 -z -c 65 -a 1 -d 4
Allocating 65 Channels...
BDF: 0000:01:00.0
Channels Allocated: 65
QDepth 508
Number of pages: 8
Completion mode: WB
PKG Gen Files: 1
DCA: OFF
All Threads exited
Leaving...
Tx   65   00:03:617   28762960.00KB  16.93GBPS    0    65   0   100.00%
Rx   65   00:03:617   25945592.00KB  09.44GBPS    0    65   0   100.00%
Total Bandwidth: 26.38GBPS, 3.46MPPS
Total TX Bandwidth: 16.93GBPS, 2.22MPPS
Total RX Bandwidth: 9.44GBPS, 1.24MPPS
Full Forms:
Please refer to perfq_log_20230125_120720.txt for more details
     total_drops:0
[root@BAPVECISE040T perfq]# ./build/mcdma-test -- -b 0000:01:00.0 -p 256 -l 2 -z -c 65 -a 1 -d 4
BDF: 0000:01:00.0
QDepth 508
Number of pages: 8
Completion mode: WB
H2D Payload Size per descriptor: 256 Bytes
D2H Payload Size per descriptor: 256 Bytes
H2D File Size: 256 Bytes
D2H File Size: 256 Bytes
PKG Gen Files: 1
DCA: OFF
All Threads exited
Leaving...
Tx   65   00:03:902   15322550.00KB  07.68GBPS    0    65   0   100.00%
Rx   65   00:03:902   1771967.50KB   00.58GBPS    0    65   0   100.00%
Total Bandwidth: 8.26GBPS, 34.65MPPS
Total TX Bandwidth: 7.68GBPS, 32.21MPPS
Total RX Bandwidth: 0.58GBPS, 2.44MPPS
Full Forms:
Please refer to perfq_log_20230125_120734.txt for more details
     total_drops:0
[root@BAPVECISE040T perfq]# ./build/mcdma-test -- -b 0000:01:00.0 -p 256 -l 2 -z -c 256 -a 1 -d 4
Allocating 256 Channels...
BDF: 0000:01:00.0
Channels Allocated: 256
QDepth 508
Number of pages: 8
Completion mode: WB
PKG Gen Files: 1
DCA: OFF
All Threads exited
Leaving...
Tx   256   00:03:976   8357743.00KB   04.02GBPS    0    256   0   100.00%
Rx   256   00:03:976   6494101.75KB   02.08GBPS    0    256   0   100.00%
Total Bandwidth: 6.10GBPS, 25.57MPPS
Total TX Bandwidth: 4.02GBPS, 16.86MPPS
Total RX Bandwidth: 2.08GBPS, 8.71MPPS
Full Forms:
Please refer to perfq_log_20230125_120746.txt for more details
     total_drops:0
wchiah
Wincent_Intel
wchiah
Hi
We have not hear from you and this Case is idling. It is not recommended to idle for too long.
Therefore following our support policy, I have to put this case in close status. My apologies if any inconvenience cause
Hence, This thread will be transitioned to community support.
If you have a new question, feel free to open a new thread to get support from Intel experts.
Otherwise, the community users will continue to help you on this thread. Thank you
If you feel your support experience was less than a 9 or 10,
please allow me to correct it before closing or let me know the cause so that I may improve your future support experience.
Wincent_Intel
