FPGA Intellectual Property
6262 Discussions
Max10 Eval Kit User Flash Memory IP
Hey everyone, I've been trying
As a sidenote - I have read the MAX10 User Flash Memory guide in its entirety no fewer than 3 times, however, I have almost zero experience in verilog.
I'm trying to use the push buttons on my development kit to "one step" my way through the Altera Flash IP core, and reading out significant signals to the leds on board as a troubleshooting tool. My problem is currently, I try to write to the CSR control register, then read back the CSR control register to verify my changes went though - they never do. Any guidance as to where to go from here (or if I'm completely off course..) would be greatly appreciated. Here's my verilog code. Thanks!
module FlashMemory(
clock,
pbs,
led
input clock;
input [3:0]pbs;
output [4:0]led;
reg[31:0] writedata = 32'h00000000;
reg[31:0] readdata;
reg[15:0] dataaddress = 16'h0004;
reg[31:0] readdatacopy = 32'hFFFFFFFF;
reg datawrite = 1'b0;
reg dataread = 1'b0;
reg burstcount = 1;
reg busy;
reg[31:0] csrwritedata = 32'h001FFFFF;
reg[31:0] csrreaddata;
reg[15:0] csraddress = 16'h0001;
reg csrhighbit = 1'b1;
reg csrwrite = 1'b0;
reg csrread= 1'b0;
reg reset;
wire pllclock;
wire locked;
wire readdataok;
reg [4:0]led = 5'b11111;
reg writebutton;
reg readbutton;
reg csrwritebutton;
reg csrreadbutton;
reg csrwriteprotection;
reg dummy = 1'b0;
reg [31:0] writetimer = 0;
always @(posedge pllclock) begin
if(dummy)begin
reset <= 1'b0;
end
else begin
reset <= 1'b1;
csrwritebutton <= pbs[0];
csrwriteprotection <= pbs[1];
csrreadbutton <= pbs[2];
if(!pbs[0] && csrwritebutton)begin
csrwritedata <= 32'h001FFFFF;
csrwrite <= 1'b1;
end else if(!pbs[1] && csrwriteprotection) begin
csrwritedata <= 32'hFFFFFFFF;
csrwrite <= 1'b1;
end else begin
csrwrite <= 1'b0;
end
if(!pbs[2] && csrreadbutton) begin
csrread <= 1'b1;
end else begin
csrread <= 1'b0;
end
if(!csrreaddata[31]) begin
csrhighbit <= csrreaddata[31];
end
if (csrread) begin
led[0] <= 1'b0;
end
if (csrhighbit)begin
led[4] <= 1'b1;
end
if (!csrhighbit)begin
led[4] <= 1'b0;
end
end
end
FlashIP FlashIP_inst (
.clock (pllclock), // clk.clk
.reset_n (reset), // nreset.reset_n
.avmm_data_addr (dataaddress), // data.address
.avmm_data_read (dataread), // .read
.avmm_data_writedata (writedata), // .writedata
.avmm_data_write (datawrite), // .write
.avmm_data_readdata (readdata), // .readdata
.avmm_data_waitrequest (busy), // .waitrequest
.avmm_data_readdatavalid (readdataok), // .readdatavalid
.avmm_data_burstcount (burstcount), // .burstcount
.avmm_csr_addr (csraddress), // csr.address
.avmm_csr_read (csrread), // .read
.avmm_csr_writedata (csrwritedata), // .writedata
.avmm_csr_write (csrwrite), // .write
.avmm_csr_readdata (csrreaddata) // .readdata
&nbsp;);
FlashPLL FlashPLL_inst (
.inclk0 ( clock ),
.c0 ( pllclock ),
.locked ( locked)
&nbsp;);
endmodule
