FPGA Intellectual Property
6673 Discussions
MegaCore Function Generation Error
I got an error using the example file "topfft.mdl" in HIL tutorial offered by Altera.
When I open the"fft_stream" FFT control window and click on "Step 2: Generate" to update the FFT megacore function, error prompts out as follows:
"MegaCore FUnction Generation Error"
"IP Functional Simulation Model Creation Failed. Code==3".
My running enviroment is "DSP builder 16.1" and "Matlabe2015b"
How can I solve this problem?
Hou
Have you tried running "alt_dspbuilder_refresh_megacore" on the command window?
