FPGA Intellectual Property
Megafunction: Switch
Hi
I came across Switch 11.0(Megafunction name) in megafunction wizard when i choose edit the existing custom megafunction variation. May i know what is the Switch 11.0?
There is no way i can find the related info.
Why you didn't press the information button in the MegaWizard?
Information button? i don't see it in the megawizard. Where it is located?
When you create an instance of the respective MegaFunction.
You are right when u know where to look for the IP in the megafunction. In my case, it is different. Previously an IP was created and i was trying to edit the parameter of the IP. So i choose to edit the existing custom megafunction variation, a dialog box pops out to let you select the IP.v file. I accidentaly came across Switch 11.0 under Megafunction name, a list of megafunction(bottom of dialog box). However, i can't find it in create new custom megafunction variation. I hope this clear the confusion.
It should help to know, that switch is a Video IP. http://www.altera.com/literature/ug/ug_vip.pdf
I also didn't know what it is, but found it in the MegaWizard within a few 10 seconds.
I overlook it. Thanks for your info.
