FPGA Intellectual Property
6603 Discussions
Missing DSP builder standard blockset
I've tried to install the DSP builder standard blockset numerous times but all I can access in the Simulink browser is the advanced blockset. I'm using matlab r2010a, does any one have any ideas or know why it is not working? Thanks for any responses.
Are you using the 64-bit version of MATLAB on Windows? If so it's not supported in 11.0.
what versions of matlab are supported by dsp builder version 11.0? (http://www.altera.com/support/kdb/solutions/rd05162011_421.html)
I remember having a similar problem. For some reason the standard blockset may not have been added to you Matlab path. You can try going to the file menu, select "Set Path" and 'Add with sub-folders' all of the folders in the DSPBuilder folder (if these folders are not already included).
RUSHALE
I'm using the 32 bit MatLab, I'll try setting the path now. Thanks for the advice I'll post after I try
Thanks you,
it was a pleasure to see altera dsp blockset in my simulink browser
Sam
