FPGA Intellectual Property
6565 Discussions
Multi channel TSE with GBX (Arria II GX)
In one of our future boards, we+re going to use an Arria II GX FPGA, which will have 5 Ethernet connection using either SGMII or 1000-X.
I'm current ly working with an Evalboard using an SMA connector daughter card, so we can connect the design to our backplane.
Since I need to group the connections in GBX group I created a MegaFunction TSE with four channel using GBX. And our logic we+re using in other design, conatining a PING module.
If I can connect to Channel 0 every works fine. I get link and can ping the FPGA. If I connect to another channel, I get link, but now activity.
I tried to connect a GBX_reconfig block, but the design doesn't compile. And end up with a message that atom is already occupied.
Also if I don't instantiated a GBX reconfig module, I'm getting a critical warning, that CMU is not connected correctly.
I checked all documentation I found, I'm not getting further. Has anybody tried to generate a TSE with multichannel and GBX ?
My bad: Forgot to write to the register of the other channels. Works now.
Hello Videoman,
I am trying to use a Multiport TSE MAC using the Altera's ST multi-channel FIFO. But any port of TSE MAC that should be connected to an external FIFO has an different associated clock. Because of that, I am not being able to connect all the ports from TSE to a Multiplexer to be latter connected on the multi-channel FIFO as suggested in the documentation. When I try to use the Altera's ST Multiplexer I get the following error messages:
"Error: System.tse: tse.receive_0 and multiplexer_0.in0 must be on the same clock domain, since they're connected"
"Error: System.tse: tse.receive_1 and multiplexer_0.in1 must be on the same clock domain, since they're connected"
... and so on for all the ports I try to fit
So, may I ask, how did u do with the external TSE FIFOs of your multiport TSE design?
Thank you
We use the RX and TX clocks to find dual clock FIFOs which go than to the target clock domain.
