FPGA Intellectual Property
Intel Support hours are Monday-Fridays, 8am-5pm PST, except Holidays. Thanks to our community members who provide support during our down time or before we get to your questions. We appreciate you!
Need Forum Guidance? Click here
Search our FPGA Knowledge Articles here.
5982 Discussions
Multiple BARs on Stratix 10 PCIE IP
S10PCIE
Do you have any error report when you use multiple BARs of "Stratix 10 Avalon-MM Interface for PCI Express Solutions" of Quartus prime pro 17.1 ? We try to use BAR0 and BAR2 on "Stratix 10 GX FPGA Development Kit" (ES version, DK-DEV-1SGX-L-0ES), which has a 1SG280LU3F50E3VGS1 device. BAR0 has no problem, but we cannot write BAR2 (no write enable signal from Hard-IP).
Nathan_R_Intel
There is no error reported when using multiple BARs on Stratix 10 AVMM for Quartus Prime Pro 17.1. All known issues are captured in the following page: https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/kdb-fi... As you mentioned you are able to write to BAR0 successfully. Hence, I am suspecting either you are not accessing the BAR address correctly or using burst mode. If burst mode is enabled; then you will need to "Enable burst capability for RX Avalon-MM BAR<n> Master ports." Please advice if you are performing the above.
