Do you have any error report when you use multiple BARs of "Stratix 10 Avalon-MM Interface for PCI Express Solutions" of Quartus prime pro 17.1 ? We try to use BAR0 and BAR2 on "Stratix 10 GX FPGA Development Kit" (ES version, DK-DEV-1SGX-L-0ES), which has a 1SG280LU3F50E3VGS1 device. BAR0 has no problem, but we cannot write BAR2 (no write enable signal from Hard-IP).
There is no error reported when using multiple BARs on Stratix 10 AVMM for Quartus Prime Pro 17.1.
All known issues are captured in the following page:
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/kdb-filter.html
As you mentioned you are able to write to BAR0 successfully. Hence, I am suspecting either you are not accessing the BAR address correctly or using burst mode. If burst mode is enabled; then you will need to "Enable burst capability for RX Avalon-MM BAR<n> Master ports."
Please advice if you are performing the above.
