FPGA Intellectual Property
NCO MegaCore Function
If I want to generate the fixed amplitude and Fixed Frequency statble Sine Wave, is NCO MegaCore Function is the right choice?
Outof the following Generation Algorithm
Small ROM
Large ROM
CORDIC and
Multiplier-Based
Which one gives the Most Stable Frequency Output?
-- megafunction wizard: %NCO v11.0%
the different generation algorithms are largely a resource/time trade off
if you have lots of extra RAM in your design, choose one of the ROM based NCOs
if you have lots of logic leftover use a parallel CORDIC
if you've got a high clock rate but low sample rate use a serial CORDIC
if you've got some multipliers left over use a multiplier based
a common specification for NCOs is spurious free dynamic range SFDR. you can get an idea of what you can achieve in the MegaWizard when you vary the parameters
