FPGA Intellectual Property
NCO Problems
志姜000
Can I implement this form of sequence with NCO,S(nT)=Asin(2πfn²T),That is, whether the phase increment changes along each clock hop.
Thank you in advance for your help.
SreekumarR_G_Intel
Can you explain what is meant by NCO here ? if you would like to implement sine function you can implement vai sine look up table stored in Intrnal RAM and apply to the logic accordinly.
志姜000
SreekumarR_G_Intel
Just had a chance to look at IP core ; looks like it is possible using NCO to generate the sine in terms of pulsed sine .
Kindly let me know if you have any question further for the same ?
志姜000
It means that NCO IP core can implement the form S(nT)=Asin(2πfnT), but it's not certain that S(nT)=Asin(2πfn²T) in this case.
YuanLi_S_Intel
This thread will be transitioned to community support. If your question is not addressed yet or you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
