FPGA Intellectual Property
6670 Discussions
Need TSE reference Design
nome
I've spent a lot of time searching on Google and within the Intel community, but I couldn't find the Arria II GX FPGA Reference Design for TSE using the GXB Transceiver. In my case, I'm using Quartus 18.1.
The only reference design I found is AN633 for Arria II GX, but it seems to be problematic due to its outdated design for Quartus 9.1, and it's missing some IP components needed for Quartus 18.1.
Could you please assist us by sharing the TSE reference design for Quartus 18.1 on the FPGA Arria II GX?
Thank you.
ZiYing_Intel
Thanks for submitting the issue. Allow me have some time to look into the issue and I will get back to you with findings.
zying
nome
Hi
Thanks for your reply
i I'll waiting your reply
nome
ZiYing_Intel
Hi nome,
May I know the OPN number and the quartus version 18.1 (standard or pro) ?
zying
nome
Hi ZiYing_Intel
Thanks your Reply
I am using Arria ii GX EP2AGX190FF35I3 obviously  We are not using Pro version .
I an using Quartus Prime Version 18.1.1 build 646 04/11/2019 SJ  standard Edition.
Nome
ZiYing_Intel
Hi nome,
I can't find the exact opn triple speed ethernet example design for you but you may try refer link below as a reference https://www.intel.com/content/www/us/en/design-example/715131/arria-10-triple-speed-ethernet-and-native-phy-design-example.html
zying
nome
Hello
Thanks for your Reply
As you share pervious post TSE Reference Design for Arria 10 . I try in Quartus 18.1 design I am getting warning below    TSE.jpg
Nome
ZiYing_Intel
Hi Nome,
I send the .qar file here. Hope that this triple speed ethernet example design is useful to you.
zying
nome
Hi ZiYing_Intel,
Thank you for your informative post.
You mentioned the Arria 10 Reference Design, which includes IP for XCVR, PHY, and other components. However, it does not support IP in the Arria II GX FPGA.
If you happen to have a reference design for the Arria II GX with GXB transceivers, could you please share it with us?
Nome
ZiYing_Intel
Hi nome,
I still can't find the triple speed ethernet example that related to Arria II since the device that you use is too old. However, you also can try find the design example through the link below https://www.rocketboards.org/foswiki/Main/WebHome
zying
ZiYing_Intel
Hi nome,
Since the device that you are using is too old, we still can't found the tse example design that related to arria ll. I would suggest you to use a new device which now the tse example design that can support it. I am now close the case. If you have any issue after the case closed, please do feel free to submit another issue. There will have people reach out to you.
zying
