FPGA Intellectual Property
PCIE errors
CLeon14
I am compiling a Q19.4 with 2 PCIe Gen3 x8 and get an errors which compiles succesfully with Q18.1.1
I get this error message:
Error(14996): The Fitter failed to find a legal placement for all periphery components
   Error(14986): After placing as many components as possible, the following errors remain:
      Error(13081): The Fitter cannot route to 1 clock core fanout
         Error(16234): No legal location could be found out of 31 considered location(s). Reasons why each location could not be used are summarized below:
            Error(177003): Fitter encountered congestion in the clock network while routing from source auto-promoted clock driver to the clock core fanout
            Error(14903): The following regions are not compatible given the current clock driver placement (30 locations affected)
BoonT_Intel
Hi Maybe you can remove all user constraint from the QSF and let quartus auto fit the design.
User1573261788318367
I have seen this error before when choosing invalid pin placement, direction, and/or I/O standard for the PCIe pins.
CLeon14
Thank you. I am able to get it fix after remove some location assignment.
