FPGA Intellectual Property
6100 Discussions
PCIe Avalon-MM DMA MSIs assignment of AN829
Ursa
Dear All,
Before starting our own project, I am trying to program the Windows KMDF driver firstly on Arria 10 GX dev board based on the AN829 example.
In the doc of AN829, I found the "Number of MSI messages requested" is 4, however I don't know the purpose of each MSI, eg. which one is for reading, writing or something else? Can anyone tell me the detailed descriptions of MSIs of AN829 example? Thanks a lot. I need to distinguish the messages from each other in ISR.
By the way, how can I assign an MSI ID for different interrupt purpose? It seems that I can only set the number of MSI messages like this.
Ursa
Rahul_S_Intel1
Hi ,
Kindly find the details of the MSI interrupt on page no: 97
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_a10_pcie_avmm.pdf
for detailed description
Ursa
@Rahul_S_Intel1 Hi Rahul,
Thanks for guiding. Looks like I need to access the register 0x3060(PCI Express to Avalon-MM Interrupt Status Register for Endpoints) to distinguish the signals, but I don't know how to access Avalon-MM Control and Status Register Address Spaces from Windows side. Should I expose these spaces through a BAR? Any suggestions? Thank you very much.
Ursa
Thanks for guiding. Looks like I need to access the register 0x3060(PCI Express to Avalon-MM Interrupt Status Register for Endpoints) to distinguish the MSI signals. But I don't know how to access the Avalon-MM Control and Status Register Address Spaces from Windows side. Should I expose these address spaces through a BAR? Any suggestions? Thank you very much.
Ursa
