FPGA Intellectual Property
6659 Discussions
PCIe Root Port functionality in Arria 10
SZack
Partner
In the Arria 10/Cyclone 10 GX Avalon MM Interface for PCIe User Guide (June 2021) Table 2 and Table 11 seem to have contradictory statements about Root Port support.   Table 2 says Root Port is supported for both the ST and MM interfaces unless DMA is enabled.  In Table 11, at the top of page 26 it says
"You can enable the Root Port in the current release.  Root Port mode only supports the Avalon-MM interface type, and it only supports basic simulation and compilation. However, the Root Port mode is not fully verified."
So is Root Port mode fully supported or not?
KhaiChein_Y_Intel
Hi
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
KhaiY
KhaiChein_Y_Intel
Root Port mode is supported in Avalon-ST interface type but example design generation for root port mode is not supported in Avalon-ST interface type.
Khai Chein
slim
The reply only refers to Avalon-ST interface.   Is the PCIe root port mode supported in Avalon-MM interface for Arria 10?
Thank you,
Sung Lim
Wideband Systems, Inc.
KhaiChein_Y_Intel
Hi
KhaiY
KhaiChein_Y_Intel
Hi Sung Lim,
Root Port mode is supported in Avalon MM interface and example design generation.
KhaiY
KhaiChein_Y_Intel
KhaiY
