FPGA Intellectual Property
6606 Discussions
PCIe link training fails, CV_DE1(rootport) <-> CVGT (endpoint)
Hi All!
I faced with the task to build a PCIe based system. For debugging a rootport part of the system I use Terasic DE1 Cyclone V GX based board equipped with special rootport<->hsmc (x1) daughter card I've developed.
Altera Cyclone V GT board is used as an endpoint.
I tested duplex data transmission through the link using simple transmitter based projects (2.5GBps). The system works well)
I check ltssmstate to view the current state of both boards when I use PCIe based projects and try to get L0 state.
The problem is that the CVGT board (endpoint) get the state ltssmstate==1 and then 2 on having got the PERSTn from root. At the same time DE1 (rootport) get ltssmstate==1 at first and finally became zero (see attachments).
How can I debug this?
Thanks in advance!!!
