FPGA Intellectual Property
6606 Discussions
PCIe simulation error: TxElecIdle not asserted
While simulating PCIe IP core using ModelSim with the testbench generated along with the IP core generation, Iam getting the following error message.
ERROR: 57 ns TxElecIdle not asserted while reset asserted, Lane: 0, MAC: RP
In the waveform obtained, it is found that at any time, either of three resets to the PCIe ip core (crst, npor, srst ) is active high, so that the design is not coming out of reset state and hence txelecidle0_ext is always active high and forces transmit output to electrical idle. Though I tried with another device and by changing parameters for PCIe generation, the result was same.
Expecting your valuable suggestions to overcome this error.
Thanks & Regards,
Gibin George
Hi Gibin,
Please try changing simulation parameters of the generated testbench.
Check if you are using PIPE/serial PHY interface and set parameters accordingly.
May be this will be helpful.
regards,
umesh
