FPGA Intellectual Property
6224 Discussions
PCIe with DMA interface locks RD_DMA_LAST_PTR reaches 127 (7F)
I have PCIe Hard IP with internal DMA interface (14.0 compiled). I wrote a PC window 7 device driver. When RD_DMA_LAST_PTR reaches 0x7Fsoftare writes 0x7F and the last descriptor ID to the PTR. The DMA completes the operation and status has been set to 1, and interrupt is sent. But it locks up.
Anyone has any idea what is wrong.
Thank you,
David
Hi David
Probably you can firstly try use the PCIe Avmm DMA example design and its software Driver that available at below link instead of your own driver.
http://www.alterawiki.com/wiki/reference_design:_gen3_x8_avmm_256-bit_dma_for_external_ddr3_-_stratix_v
Why not you firstly try to use the PCIe Avmm DMA example design and its software Driver available at below link instead of your own driver.
Hi Skbeh,
I have Cyclone V only. I have work around with this issue with driver to 128 a time. DMA is fast, it doesn't have any performance hit.
Thank you,
If your DMA controller is doing Avalon burst transfers into the Txs port of the PCIe block then the maximum burst size is limited to (I believe) that which will normally generate a single TLP - ie burst 16 giving TLPs of 128 bytes with a 64bit interface.
The 'simple' dma controller can't be configured to do that for lomng transfers.
The 'scatter-gather' DMA controller can, but it is a bit like using an atomic bomb to shell a peanut.
OTOH if you are talking about the new DMA interface within the PCIe block itself I can't help.
