FPGA Intellectual Property
PIO performance
I use IORD and IOWR to control the PIO and it seems the speed will be no more than 15MHz. Is there any way to accelerate?
use SG-DMA.(scatter gather DMA).
Thanks akira. Could you give me details about how to use it in SOPC and control it in Nios? I read the document but it was not that clear.
since I don't have much time to tell you.
I just tell you a point.
- SOPC builder has SG-DMA.
- SG-DMA creates Avalon-ST data stream.
- sample of DMA is in NiosII IDE template.
it may take time to learn by yourself.
but you need this skill if you need more than 100MB/sec.
I'm sorry for now.
Thanks again. I will try to understand it. Please leave me some detail/hint when you have time
FYI it's not that the PIO is slow, the processor accessing the PIO can't access it every clock cycle. If you wired a DMA up to the PIO you could potentially change the output every clock cycle.
great solution BadOmen !!
Hi BadOmen,
Could you explain more about the HDL driver? I read the document about these APIs. Do you mean that I need to give the base address of some PIO to sgdma?
It will be perfect that you can show me a simply diagram of the whole connection.
Thanks!
It's pretty easy actually. With the DMA you basically read a buffer from memory and have the DMA write to a fixed address. The bit in the control field for writing to a fixed address is called "WCON" I think. There is something similar in the SGDMA but I forget what the bit is called. Take a look at this design, it does something similar: http://www.altera.com/support/examples/nios2/exm-crc-acceleration.html (http://www.altera.com/support/examples/nios2/exm-crc-acceleration.html?gsa_pos=1&wt.oss_r=1&wt.oss=crc)
