FPGA Intellectual Property
PIO performance
Colaborador honorário II
1.754 Visualizações
I use IORD and IOWR to control the PIO and it seems the speed will be no more than 15MHz. Is there any way to accelerate?
8 Respostas
849 Visualizações
use SG-DMA.(scatter gather DMA).
849 Visualizações
Thanks akira. Could you give me details about how to use it in SOPC and control it in Nios? I read the document but it was not that clear.
849 Visualizações
since I don't have much time to tell you.
I just tell you a point.
- SOPC builder has SG-DMA.
- SG-DMA creates Avalon-ST data stream.
- sample of DMA is in NiosII IDE template.
it may take time to learn by yourself.
but you need this skill if you need more than 100MB/sec.
I'm sorry for now.
849 Visualizações
Thanks again. I will try to understand it. Please leave me some detail/hint when you have time
849 Visualizações
FYI it's not that the PIO is slow, the processor accessing the PIO can't access it every clock cycle. If you wired a DMA up to the PIO you could potentially change the output every clock cycle.
849 Visualizações
great solution BadOmen !!
849 Visualizações
Hi BadOmen,
Could you explain more about the HDL driver? I read the document about these APIs. Do you mean that I need to give the base address of some PIO to sgdma?
It will be perfect that you can show me a simply diagram of the whole connection.
Thanks!
849 Visualizações
It's pretty easy actually. With the DMA you basically read a buffer from memory and have the DMA write to a fixed address. The bit in the control field for writing to a fixed address is called "WCON" I think. There is something similar in the SGDMA but I forget what the bit is called. Take a look at this design, it does something similar: http://www.altera.com/support/examples/nios2/exm-crc-acceleration.html (http://www.altera.com/support/examples/nios2/exm-crc-acceleration.html?gsa_pos=1&wt.oss_r=1&wt.oss=crc)
Responder
