FPGA Intellectual Property
6359 Discussions
PLL_50_100 usage: Simulation refers to wrong path of altera_mf.v and simulation hangs.
SDesa16
Our design is targeted on Altera max 10. It uses PLL_50_100. I am using Questasim for simulation. I have setup the Altera library files. I can see them in GUI too. Though it goes through the compilation,loading, simulation hangs with the last line being:
# Time: 90 Instance: tb_ov1_top.inst_PLL_50_100.altpll_component.cycloneiii_pll.pll3
And when i break the simulation, i get below error.
# Break in Module MF_cycloneiii_pll at /build/swbuild/SJ/nightly/18.1std/625/l64/work/modelsim/eda/sim_lib/altera_mf.v line 16981
# Error opening C:/build/swbuild/SJ/nightly/18.1std/625/l64/work/modelsim/eda/sim_lib/altera_mf.v
# Path name 'C:/build/swbuild/SJ/nightly/18.1std/625/l64/work/modelsim/eda/sim_lib/altera_mf.v' doesn't exist.
My TCL script uses required args:
vsim -t 1ns -L altera_mf_ver -L fiftyfivenm_ver -L work -voptargs="+acc" ..................
Please give some insight into this issue?
SDesa16
Any lead to this question?
What could be the reason for below error (after hit the break)?
RichardTanSY_Intel
Apologize for the delay in response. Can you send me the design file? So I can try run it using Questasim and come back to you.
