FPGA Intellectual Property
6673 Discussions
Parallel Flash Loader IP - mapping ports problem
Gyud0
hey,
I was creating the Parallel Flash Loader IP by Quartus MegaFunction.
I integrated this IP in the Top design file( add the IP's ports, declare the IP, mapping the IP to the Top's port). Then I mapped the ports to the FPGA's I/O and I got problems in Quartus (in the Fitter stage) about multiple pins assignments for these mapping routes. they collides with reserved Altera pins:
Error(176310): can't place multiple pins assigned to pin location Pin_E2 (IOPAD_X0_Y36_N7)
Info(176311) : pin flash_nce is assigned to pin location Pin_E2
Info(176311) : pin ~AlLTERA_FLASH_nCE_nCSO~ is assigned to pin location Pin_E2
this is the component ports:
component parallel_flash_loader is
port (
pfl_flash_access_granted: in std_logic;
pfl_nreset:in std_logic;
flash_addr: out std_logic_vector(22 downto 0);
flash_data:inout std_logic_vector(15 downto 0);
flash_nce: out std_logic;
flash_noe: out std_logic;
flash_nwe:out std_logic;
pfl_flash_access_request:out std_logic
end component parallel_flash_loader ;
I need some help here, thank you
NurAiman_M_Intel
Thank you for contacting Intel community.
Have you refer to Intel PFL guideline below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_pfl.pdf
Let me know if you need further information.
Aiman
Gyud0
Hey,
in this guide I see that the PFL not support active-parallel configuration (only passive-serial and fast-passive-parrallel). Can you suggest me a way to configure the FPGA by Active parallel?
THX,
NurAiman_M_Intel
Active parallel only support old FPGA device and do not support new FPGA. May i know which FPGA device family that you are using?
Thank you.
Aiman
Gyud0
NurAiman_M_Intel
By active parallel, do you mean Active Serial?
Aiman
Gyud0
Active parallel means that I want the flash program several FPGA's (2 in my case) in the same time.
NurAiman_M_Intel
NurAiman_M_Intel
I believe my previous response has address your question since there is no update on this case. Hence i will proceed to close this case, but please noted you can re-open this case within 10 days or create a new case if you need further information.
Thank you.
Aiman
