FPGA Intellectual Property
6673 Discussions
Pause needed between multiple DMA transfers?
I try to sequentially read buffers from PIO at the fastest possible
speed with NIOS II/f. Everything works fine, however the speed
seems to be limited to ~25 MB/s, independently of the buffer size.
The essential part of the C-code is:
while (Nr < NrBuffers) {
Nr++;
if ((rc = alt_dma_rxchan_prepare(rxchan, rx_buffer, NrBytes - 1, done,
NULL)) < 0) {
printf("Failed to post read request, reason = %i\n", rc);
exit(1);
while (!rx_done); // wait for transfer to complete
// necessary pause
usleep(40);
With NrBuffers= 100000 and NrBytes= 1000 (
a total of 100 MByes) this takes about 4 s, hence
the ~25 MB/s. Note that usleep(40) alone accounts
for the entire 4 s (40E-6x1E5= 4 s). Larger buffers
need larges pauses, hence the aforementioned
maximum speed of ~25 MB/s.
However, with the shorter pause usleep(30)
alt_dma_rxchan_prepare gives error message -28=
ENOSPC= No space left on device. In addition,
the program starts at the top, resulting in an
infinite loop of starts and ENOSPC messages.
On the other hand, usleep(30) with a small
NrBuffers= 5 works fine.
Apparently, calling many alt_dma_rxchan_prepare's
too fast (although the data is transferred) after
each other is upsetting things seriously.
I tried to adjust some settings of the DMA core
(enable burst transfers, larger FIFO depth) to no
avail.
Any idea how I can solve this?
Thanks!
Jos
Your description sounds like you have a bug in your done() callback and rx_done handshake. For example, you might get the behavior you described if you had never reset rx_done back to zero before starting the next transfer.
You are completely right, thanks! I copied the done() and rx_done part from somewhere
without giving it sufficient attention. By resetting rx_done back to 0 when needed
I can now omit the usleep(). However, I still am stuck at the ~25 MB/s. The next
puzzle...
