FPGA Intellectual Property
Pipeline Bridge
i have a problem with the address calculation of the pipeline bridge.
I'am using Quartus 10.0 Sp1 and SOPC Builder.
To increase the system frequency, i want to use a pipeline bridge
tha is connected to a tristate bridge.
the tristate bridge is connected to three memories.
( See attachment )
Flash : 0x00000000 .. 0x03ffffff (64 MByte)
SRAM : 0x04000000 .. 0x040fffff ( 1 MByte )
FE-RAM : 0x04100000 .. 0x04101fff ( 8 KByte )
The "Base Address" from the Pipeline Bridge is 0x00000000 !
SOPC Calculates the "End Address" 0x07ffffff. Why ?
I expect that the "End Address" must have 0x04101fff.
Can anyone explain the address calculation of the pipeline bridge ?
Because the address decode will always ignore low order bits - or, equiv, all items are 2^n bits wide.
This is from chapter 11 of Quartus Handbook (Avalon Memory-Mapped Bridges):
"The address span of an Avalon-MM bridge is the smallest power-of-two size that
encompasses all of its slave’s ranges."
Thank you for your answers.
Ok. Any Bridge, (Clock Crossing or Pipeline) delivers a new Master Port to the Components that are enclosed from the Bridge.
If i want to Address (64 MByte + 1 MByte + 8KByte), the Master Port needs 27 Address lines to access all slave addresses.
2^27 = 128 MByte = 0x07FFFFFF
Result:
The Address Range for my Pipeline Bridge is 0x00000000..0x07FFFFFF
I have to think better soon ;-)
