FPGA Intellectual Property
6670 Discussions
Problem understanding de-interlacer core.
I'm trying to implement the De-interlacer core with the following spec,
Algorithm - Bob scanline duplication with no buffering.
Output frame rate = Input field rate.
Clock frequency = 25 MHz.
I have assumed the output to be as in the picture (pl refer attachment - output.jpg)
With reference to that I expected one pixel output per clock but when I simulated it in Modelsim I found the output to be one pixel for 4 clock cycle (Pl refer attachement pic5, pic6, pic7).
pic5 - zoom out of initial packet formation.
pic6 - zoom in of packet formation.
pic7 - after a few clock cycle from the start of packet.
The pic also contains the generation of avalon-ST signal (SOP,EOP,VALID etc)...Kindly let me know if i'm generating proper signals.
also regarding the packet formation for avalon-st, should i make each line in a frame as a packet or can i take the entire frame as one single packet?
I wanted to know if there are any data sheet or documentation available on the Deinterlacer core or any timing diagram regarding the functionality of the core. I already went through VIP user guide.
Thanks and regards,
Arthes
Hello Arthes,
it's passed a while from your post so I think that now you are definitely working on something else :)
Anyway, I'm working with something similar. I could tell you that a packet information is related to an entire frame and not a sinlgle line. In fact, if you look at control packet just previous to a video packet, you would read information about the frame that is going to come (like width, height, interlaced or progressive ecc.)
I'd like to ask you: did the deinterlacer with bob algorithm work well? Have you tested it?
Thank you
