FPGA Intellectual Property
6462 Discussions
Problem with EPCQ-L1024 extended QUAD input fast transfer
OPakh
I have a problem with EPCQ-L1024 extended QUAD input fast transfer.
For communication with it I use "Generic Serial Flash Interface Intel FPGA IP"
It works good in 1x mode but when I send command EBh lines DQ2-3 are always in 1
For example
master_write_32 $mp $operating_protocols_setting 0x00022002
master_write_32 $mp $control_register 0x00000101
master_write_32 $mp $read_instr 0x00000AEB
master_read_32 $mp 0x00000100 0x1
Lines DQ[2], DQ[3] are not used. What may be the problem?
I use Quartus 18.1(Windows 10), Arria 10 GX
ShafiqY_Intel
Hi OPakh,
If you want to enter the QUAD mode, you need to enable the QUAD mode first.
This is the step to enable the QUAD mode:
set flash_cmd_setting [expr {$base + 0x1c}]
set flash_cmd_ctrl [expr {$base + 0x20}]
master_write_32 $mp $flash_cmd_setting 0x00000035
master_write_32 $mp $flash_cmd_ctrl 0x1
I hope this will help.
Thanks😉
