Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
Problem with the FFT MegaCore
Hi All,
I am trying to run SignalCompiler block VIA C code (i.e- not manually, VIA my own application).
When I run it and use "Normal" blocks everything works fine. However, when I run it with the FFT IP core I'm having problems.
When I try to run SignalCompiler block manually the following situations occur:
1) When I manually run SignalCompiler without generating the FFT files first (using the IP Testbench)- I see that the HDL files are not generated correctly. The files are created in the same way as when I run the SignalCompiler from my C code.
2) When I manuuly run SignalCompiler after generating the FFt files- I see that everything is generated correctly.
This leads me to the conclusion that I don't call the SignalCompiler block in a correct way, when using the FFT IP core (or any other core, for that matter).
Can anyone here tell me how to call the SignalCompiler block from C code when there is an IP CORE in the design?
10x,
Gilad
hi,can u just mail me the mdl to me on dileepkumararava(at d rate)gmail(.)com...iam hardly trying to get the fft output
