Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Honored Contributor I
Problema with ip_compiler for PCI express under QSYS
Under qsys, if I insert a component "ip_compiler for PCI Express" , when generating HDL the following errors appear:
Error (114000): Time value Mbps Mbps and time unit are illegal
Error (114000): Time value 125.0MHz MHz and time unit are illegal
My FPGA is a Cyclone IV GXI am using Quartus II 15.0.1
Highlighted
Hi ramon_garcia,
That is the data rate you place in? The socond 125Mhz seems valid though :p
Highlighted
--- Quote Start ---
--- Quote End ---
Mind share further on the configuration that you are using? I tried with my Quartus II 15.0 and seems like no issue generating the HDL.
Highlighted
--- Quote Start ---
--- Quote End ---
I can reproduce the problem by inserting the component "IP compiler for PCI Express" (the only one available for PCI Express for a Cyclone IV) with the default settings. That is, start with a clean design in QSYS (only the default clock), insert IP Compiler for PCI Express, and click "Generate".
I am using Quartus II 15.0.1 for Linux, but I had the same problem with Quartus II 14.0 and 14.1
Highlighted
Finally, I found the reason for this problem.
It is a bug in the Linux version.
Under Windows, it works perfectly.
So I have to switch development to Windows.
Highlighted
Glad to hear that you have managed to get it work with Windows.
