FPGA Intellectual Property
6673 Discussions
Problems when using FIFO IP for simulation
XQSHEN
I defined a IP based on original Intel FIFO IP, and used in platform designer.
module adc_fifo(
 sink_clk,    //50MHz
 source_clk,   //75MHz
 reset_n,
 sink_avalonst_data,
 sink_avalonst_valid,
 sink_avalonst_ready,
 source_avalonst_data,
 source_avalonst_valid,
 source_avalonst_ready,
 fifo_ready
 input    sink_clk;
 input    source_clk;
 input    reset_n;
 input [15:0]  sink_avalonst_data;
 input    sink_avalonst_valid;
 output    sink_avalonst_ready;
 output [63:0]  source_avalonst_data;
 output    source_avalonst_valid;
 input    source_avalonst_ready;
 output    fifo_ready;
  part 0: Internal parameter
 wire [8:0]    rdusedw;
  part 1: FIFO
 adcfifo fifo(
  .data  (sink_avalonst_data),
  .wrclk  (sink_clk),
  .wrreq  (sink_avalonst_valid),
  .q   (source_avalonst_data),
  .rdclk  (source_clk),
  .rdreq  (source_avalonst_ready),
  .rdusedw (rdusedw),
  .aclr   (~reset_n)
 assign source_avalonst_valid = rdusedw[8] & reset_n;
 assign sink_avalonst_ready = (rdusedw < 9'd511);
 assign fifo_ready = rdusedw[8] & reset_n;
endmodule
It can not be successfully simulated in modelsim-intel. Based on IP, it requires altera_mf.
This is already in modelsim searched libraries. So I don't know why it still fails.
The error message is as below. adcfifo is qip I generated based on Intel FIFO IP.
adc_fifo.v(41): Instantiation of 'adcfifo' failed. The design unit was not found.
#         Searched libraries:
#             C:/intelFPGA/18.0/modelsim_ae/altera/verilog/altera
#             C:/intelFPGA/18.0/modelsim_ae/altera/verilog/220model
#             C:/intelFPGA/18.0/modelsim_ae/altera/verilog/sgate
#             C:/intelFPGA/18.0/modelsim_ae/altera/verilog/altera_mf
#             C:/intelFPGA/18.0/modelsim_ae/altera/verilog/altera_lnsim
#             C:/intelFPGA/18.0/modelsim_ae/altera/verilog/fiftyfivenm
RichardTanSY_Altera
I guessing line 41 start from here:
 adcfifo fifo(
  .wrclk  (sink_clk),
  .rdusedw (rdusedw),
  .aclr   (~reset_n)
Modelsim can't find the so-called adcfifo.v file and I guess the adcfifo.v is in the adcfifo.qip that you generated based on Intel FIFO IP. Add the qip in your project, compile and simulate again.
XQSHEN
Yes, the adcfifo.v is in the qip files. Actually I already include qip in below two methods, but it still doesn't work.
1) add qip through assignment - > setting - > files
2) add qip in platform designer -> component editor -> files -> both synthese file and simulation files.
RichardTanSY_Altera
Which Quartus version are you using? Standard or pro?
Could you share your project so I can investigate further? A simplified design that can duplicate the issue will do.
XQSHEN
Quartus prime 18.0, standard version.
I just solved the issue by adding adcfifo.v in the component editor simulation files.
1) Add adcfifo.v  --> it works.
2) Add adcfifo.qip --> it doesn't work.
