FPGA Intellectual Property
6670 Discussions
Problems with PCI express IP Compiler and Pin Planner
Hi, I began to study PCI Express system in order to implement on a FPGA. I'm using Stratix II GX development Kit board and i already am at the point to connect the pins of the FPGA using the Pin Planner Editor. The problem is that i don't know how to relate the signals in the top level generated by de PCI Express Ip Compiler and the correct pins on the FPGA. I really appreciate if anybody can give me a correct assignment file. The target FPGA is the EP2SGX90FF1508C3. Thank you very much in advance
First, you need refer to Figure 5–41 of IP Compiler for PCIe User Guide to understand the PCIe Rx/Tx transceiver channels location assignments.
The assignment is like this:
Transceiver Ch0 --> PCIe Rx0/TX0
Transceiver Ch1 --> PCIe Rx1/TX1
Transceiver Ch2 --> PCIe Rx2/TX2
Transceiver Ch3 --> PCIe Rx3/TX3
... and so on
The refer to the Stratix II device pin-out files to know the pin location assignment.
