Planned to Migrate Ptile PCIe to Htile PCIe, but the below Ptile PCIe signals not availble in Htile PCIe IP. Application layer uses the p0_rx_st_hdr_o signal, so need to know how to handle this in Htile IP.
p0_rx_st_hdr_o
p0_rx_st_tlp_prfx_o
p0_rx_st_bar_range_o
p0_rx_st_tlp_abort_o
p0_rx_par_err_o
Thanks!
Hi ,
Kindly allow me some time to look on your issue
Hi ,
I understand your concern, to clarify your question.
The Ptile supports different type of configuration (1x16, 2x8 or 4x4) , so the value of below signal will change depends up on the configration.
p0_rx_st_data_o[127:0], p0_rx_st_hdr_o[127:0] and
p0_rx_st_tlp_prfx_o[31:0].
Ref:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_ptile_pcie_avst.pdf
page no:41
But the same is not been in the S10 H tile device
Ref:
Page no:52
- Tags:
- Hi
we need x8 configuration, so in Ptile the P1 interface driven by "0" and only P0 interface is used for application layer transaction.
>>>> H tile bus width details >>>>
p0_rx_st_data_o[256:0], p0_rx_st_hdr_o[127:0] and
While migrate to Htile we are choosing Gen3x8,256bit configuration. Am also referring the documents which you shared in this thread. In Htile, seems like header information is available in the data bus itself.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/archives/ug-s10-pcie-avst-17.1ir1.pdf [page no : 53.]
If my understanding is correct, I need to add glue logic to handle this variation or any adapter is availble to separate the header information from the data bus.
If my understanding is not correct, please provide the correct direction.
Hi ,
Kindy note that , the architecture of P tile Avalon ST PCIe is different from the H Tile Avalon ST PCIe Ip. And the migration from Ptile to H tile you need separate logic.
Kindly find the attached two figures for Avalon ST ip for p tile and h tile .
And also please note that , we do not have any app note or reference design for the migration
- Tags:
- Hi
p tile and h tile
Actually, the attached waveforms are the reference to start the separate logic for migration activity. what am trying to do using separate logic means, separate the header information from pcie_rx_st_data and drives this header information into application app_rx_st_hdr signal and remaining data information into app_rx_st_data signal.
Am in wrong direction?
What the separate logic need to do, to migrate Ptile to Htile PCIe.
Thanks!
I do not have a solid example design or an App note for the migration.
Rahul S
The Glue logic update is done to handle the Htile header information and verified in the lab.
Velmurugan B
