HI,
Yup, as you can see from your own error screenshot, it's not supported.
dlim
Are you saying you want to drive the external memory at a lower speed or run the internal logic at a lower speed? The internal logic runs, based on your current setting, at 1/4 the speed (quarter rate mode) of the external memory clock. If you're saying you want to run the external memory at a lower speed, then you can't, as the message indicates.
HI,
dlim
You are welcome !
