FPGA Intellectual Property
Registers
I implemented a algorithm using DSP Builder and it has some interactions and acculumators. It needs to wait some time to continue processing by another part of algorithm.
I need some variable or register to store this value. I try to use a DRAM, but it need to treat times of read/write.
Please, can I used one more simple block or another solution to this?
Oswaldo Fratini Filho
Use a template in the quartus editor if you only need a few registers. The compiler will convert this to either use LUTs or on chip memory based on size and number of ports.
