FPGA Intellectual Property
6157 Discussions
Rx block lock in E-Tile Hard IP for Ethernet
Ajas
I am doing simulation using E-Tile Hard IP for Ethernet with 25G x 4channels . Tx  serial lines are looped back to Rx.
Rx_block_lock signal is getting asserted for the first time reset is released . (i_sl_csr_rst_n, i_sl_tx_rst_n, i_sl_rx_rst_n and i_reconfig_reset together)  and also other status signals such as rx_pcs_ready, ehip_ready, tx_lanes_stable. But after that, if i_sl_tx_rst_n and i_sl_rx_rst_n are asserted and de-asserted, rx_block_lock is not getting asserted for all 4 channels. only for channel 1 it is getting asserted.
As per my understanding, if the clock, reset and serial connection is proper, rx_block_lock will be asserted, as it is IP's logic. So I am not sure what is causing the above behavior.
Please provide any suggestion to overcome this issue. any kind of setting for simulation to be done or similar.
Aj.
SengKok_L_Intel
I have performed a simulation by asserting the sl_tx_rst_n & sl_rx_rst_n signals for 10 clock cycles after the rx_block_lock signals are locked.
Please refer to the attached simulation waveform, after triggered the sl_tx_rst_n & sl_rx_rst_n signals, the rx_block_lock becomes 0, however, after some time, it is able to lock again.
Therefore, I don't see the problem that you encountered, perhaps, you may need to run the simulation slightly longer to see if this is able to lock.
Ajas
thank you for the response.
is it with PTP configuration or only Ethernet?
SengKok_L_Intel
I was running with Ethernet without 1588 enabled.
Ajas
Thank you for the reply.
I am running with PTP configuration. As soon as the tx/rx_rstn de-asserted, local_fault signal is also asserted. Could you please suggest in which scenario in simulation, local_fault would assert, incase of loopback?
SengKok_L_Intel
After asserted tx/rxrstn, does the local_fault de-asserted? Or it stays asserted?
Ajas
It gets asserted after de-assertion of reset. and stays asserted.
SengKok_L_Intel
Below is what I observed in the simulation:
After asserted tx/rx rstn again, the IP will take some time to block lock, and then asserted the *_ready signals.
During this period, the signal may not stable, and the local_fault signal can be asserted. However, after the *_ready signals are asserted, the local_fault signal will stay low.
This is NOT expected if the local_fault signal always stays high after de-asserted the tx/rx rstn.
SengKok_L_Intel
In your simulation, you may check the local_fault signals again after the *_ready signals are asserted.
Ajas
Thank you for the suggestion.
Could you please suggest any reason for local_fault to be asserted? as it stays high even after the ready signals(ehip_ready, tx_lanes_stable) are asserted?
SengKok_L_Intel
It could be due to the block boundary is not aligned yet. You can refer to *_pcs_ready signal.
SengKok_L_Intel
If further support is needed in this thread, please post a response within 15 days. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
