How can I determine SCL_LOW, SCL_HIGH, SDA_HOLD register value of Intel FPGA Avalon I2C Master Core?
I am planning to initialize the Core from my own designed sequencer.
Thank you.
See attached.
You can refer to this document for more details. Let me know if you need further help.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_embedded_ip.pdf#page=173
No, I mentioned register value not the register location.
I am expecting all these timing is the timing while master driving SCL and SDA by itself.
I easily determine SCL_LOW and SCL_HIGH to define SCL waveform.
But I don't get what SDA_HOLD is.
I expect it is the time to sustain SDA from SCL low or high.
Let's say with a 100MHz input clock and the I2C Master is operating in normal mode of 100KHz.
For SCL_HIGH and SCL_LOW, the register value is (10us/10ns) divide by 2 assuming high and low is same (duty cycle 50:50). For SDA_HOLD, it is (your desired hold period/10ns).
I have a simple question for SDA_HOLD.
- is this timing spec when SDA as output or as input?
- is this timing spec for start/stop condition or data transfer?
