FPGA Intellectual Property
6225 Discussions
SDI TX XCVR Failed to work
Bin_Wang
  I am using the C10 GX105YF708 for SDI project.
For unknown reason, when I have both HDMI+SDI Tx core in the project.
The SDI tx_pll_locked and gxb_tx_ready will stay low..
HDMI TX core, IOLL_RECONFIG function will get values 0 after reconfiguration.
If I remove the HDMI core, SDI will work fine.
I am using Quartus Prime Pro 19.2.0.
SDI TX located at IO Bank 1D, Pin J28
HDMI located at IO Bank 1C, Pin AA28, AC28, AE28 and AG28
The reference is running as well as board booted up.
Please help me debug this weird issue.
Thank you!
BRs,
Bin
CheePin_C_Intel
Hi Bin,
As I understand it, you observe some problems with your design with the SDI TX core. Based on my understanding, there should be no dependency between HDMI and SDI cores. To further narrow down the problem, just to check with you on the following:
1. Are the CLKUSR and refclk to TX PLL to the SDI TX directly sourced from free-running oscillators on board? This is to ensure successful power up calibration.
2. From your description, seems like the tx_pll_locked stays low. We can narrow down our focus here because without the TX PLL achieving lock, the SDI TX will not work. Just to check with you which TX PLL type are you using?
3. Can you try with the latest Q21.2Pro to see if this problem persists? This is to isolate any Quartus dependent problem and any known issue which might have been fixed from Q19.2 to Q21.2 releases.
4. Is there any relation between the HDMI core and the SDI core? For example, sharing the same PLL and etc.
5. Please check through the Quartus compilation warnings to see if you can spot any anomaly ie TX PLL spacing rules violation and etc.
Please let me know if there is any concern. Thank you.
Bin_Wang
Hi CheePin,
  I am sure that the CLKUSR and refclk to TX PLL are free running..
Both are using fPLL, following the reference project. HDMI is using FPLL_1CB, SDI is using 1DB
I don't have the license for new Q Pro..
No, there's no relation between HDMI and SDI..
OK, I will check.. I knew there limitation about using ATX PLL but it should work for fPLL..
We noticed that when the board is up, the 1st time sof downloading, SDI is not working.
But if we download the same sof again.. SDI will be back to work..
Any thought?
BRs,
Bin
Bin_Wang
Dear CheePin,
I have tried to compile the project in Quartus 21.2pro, but there are some error occurred. The project was set up in Quartus 19.2pro.
The error listed:
1)More than 1 positional argument specified:,0.299...
2)ERROR: An erroroccurred during automatic periphery placement...
I don't know whether some env need to change when using 21.2pro.
So I attached the project, could you help to give some suggestion?
Thank you.
CheePin_C_Intel
Thanks for your update. Regarding your latest observation on the following:
But if we download the same sof again.. SDI will be back to work.. Any thought?
[CP] Based on my experience, generally this observation happens to the system which the refclk or the CLKUSR is not available or stable during device power up. After the first power up, the XCVR is not properly calibrated and thus cannot function properly. With the second programming of the SOF, this time, the clocks are already stable, the calibration is successful and the XCVR will function properly.
Another case of this is some of the clock oscillators are programmed by the FPGA. These clocks are only available after FPGA is in user mode.
You can try a user recalibration to the SDI TX transceiver to see if it will bring it after the first SOF downloading.
Chee Pin
JLee25
Hi Chee Pin,
  I think you suggestion to do the recalibration by following the XCVR UG, right!
SDI did not have this interface opened by default, do you have any reference data for me?
Besides to download the sof twice, we also noticed if we remove the HDMI IP.
The SDI is always fine, it will start running the 1st time.
Do you think what might be wrong?
Thank you!
Bin
CheePin_C_Intel
Sorry for the delay. Yes, you are right. I am referring to the XCVR user recalibration. If I understand it correctly, in C10 device, the Native PHY is a separate entity from the SDI II IP. You can perform the user recalibration through the dynamic reconfiguration AVMM interface.
As for the interference with the HDMI IP, sorry as I am not sure what might be wrong. Just wonder if you have tested using CMU PLL for the SDI and placing the SDI and HDMI in different XCVR banks just to help narrowing down the issue.
Chee Pin
Bin_Wang
Dear CheePin,
The error listed:
Thank you.
Please refer to following link:
community.intel.com/t5/FPGA-Intellectual-Property/SDI-TX-XCVR-Failed-to-work/m-p/1320318#M24816
