FPGA Intellectual Property
6103 Discussions
SDRAM BeMicro Max 10
CLa_R
I acquired a BeMicro Max 10 evalutation board from Arrow components.
For my first time, I would like to use the SDRAM on board (an ISSI IS42S16400J) with my project, but I never  have used the SDRAM components from Altera IP in Quartus II.
Have you some suggestion for me, please?
sstrell
You created the IP in a Platform Designer system and didn't connect anything to it.
It would probably be best to start with an example design.  You can download example designs for different versions of Quartus here:
https://fpgacloud.intel.com/devstore/platform/?board=4
CLa_R
I'm trying to instantiate a SDRAM Controller from Quartus II -> Tools -> Platform Designer -> Memory interface and controllers ->SDRAM -> SDRAM Controller.
I set the timing parametters according with my SDRAM datasheet:
But I obtain two errors.
This is the correct way for to use my BeMicro 10 SDRAM?
Why I obtain the errors?
sstrell
